Mercruiser oil recommends
jaylamb
Greetings,I have an 86 Cobia with a 140hp 3 litre 4cylinder Mercruiser.The motor tag states 30 wt. for the engine oil.I know back then that was the standard but muti weights have come along ways,I notice Merc's Quicksilver line has a 25w40 they state on the can works in all Mercruiser motors.Just wonder what some of you guys are running for motor oil in your motors?
dubs283
Re: Mercruiser oil recommends
either 30W or 25W40 will be sufficient for your engine
i use 25W40
Aloysius
DO NOt use an "energy efficient" oil with the "starburst" logo on it. These oils contain no additives to protect flat tappet cams. most modern engines use roller lifters, and the ZDDP (zinc) additive that usedta protect lifters is omitted, as it contaminated catalytic converters.
