reelfishin
- Joined
- Mar 19, 2007
- 3,050
I have several good used Merc 110 and 120 out drives, I no longer have an I/O boat but am in need of an outdrive for an older Mercury 85HP inline 6 outboard.
I was wondering if I can use an I/O outdrive on an outboard? It appears as if I can just swap drive shafts and it should fit?
I realize that the gear ratio may be different, but I can adjust for that with a prop change.
The bolt pattern and diameter look the same.
Does anyone know if this will work?
