mastercylinder63
- Joined
- Jun 13, 2010
- 36
Thanks
Oh really!if you didn't replace the gimbal bearing i wouldn't worry too much about the alignment
Oh really!
You are supposed to check the alignment annually. Actually, has little to do with the gimbal bearing and everything with the engine mounts on the stringers.
I check engine alignment every time I take a drive off. It's just foolish not to. Boats take a pounding, things move, shift, and settle.
I figured it should be an easy transition. I guess not!!!
You can get the drive on. You will also eventually destroy the coupler if the alignment is out. Just takes a little bit of being out to destroy the coupler.yep...really
if the gimbal bearing is out of alignment, you will NEVER get the drive on...ever
Advice that Dubs gave is BAD advice and should not be followed.
Checking the alignment of the gimbal bearing is not just checking if the gimbal bearing rocked in it carrier. Checking the gimbal alignment means checking the alignment between the gimbal bearing and the engine coupler. In order to get the engine coupler in alignment with the coupler, it is necessary to adjust the front of the engine. If you engine/ gimbal bearing alignment is slightly out, you can still get the drive on but you will be wearing out your coupler.if you read my previous post again you will see i never advised anyone to not check the ENGINE alignment, i merely stated that if the OP got the drive back on that the GIMBAL BEARING was not misaligned and that i doubted the engine aligment changed in between their pulling the drive and re-installing it
