Mercruiser outdrive questions
redwolf65473
I just bought a used boat. It is a glaston 1980 I knew it had one problem which is a starter issue. It needs a new one LOL. But I cant get my trim to go up or down. I made sure to pull the supports out first. When I hit the up and down button I get the sound of a pump but no action. If anyone has any ideas on how to fix this it would be greatly appreciated.
The-Machinist
Re: Mercruiser outdrive questions
Hello brother, Glad to see you made it over here to Iboats. Best place I have found. Good luck with your first inboard, your gonna need it:)
But seriously, these guys are some of the best you will find with any boating problems you may have.
So post away, I cant wait to hear you get it going(your gonna let me drive right?):D
redwolf65473
Ok more specifics on what it is im sorry. its a 1980 glastron v195. It has a mercruiser power trim 260 on it. and the derial number for the merc is 5497681
Ayuh,..... Is there any Oil in it,..??..??
redwolf65473
You know I was checking the fluid but im not sure where to put the fluid at and I dont see a place to check it. I might be more boat retarded than i thought LOL
ziggy
if ya get that service manual provided. on pp 5-17 is a pic of where ya fill at.... probably, ft, starboard side. is a screw that is below the top of the resivour... that screw is where ya fill at. or can look to see if there's any fluid in there at all....
