1996 Mercruiser 4.3LXgen+ SN:0F826592
I have a power steering issue. In short the system steers hard at all times and conditions. Steering control valve and actuator is a newer style with no serviceable parts.
A bit of trouble shooting has brought me to this. The control valve is not moving enough with input from steering wheel via the steering cable. If I assist the control valve by pushing or pulling on the end of the valve where the steering cable attaches, all works fine. Without the extra input no power steering.
So a couple of questions.
1. Is this a control valve issue? Simply replace the control valve and actuator assembly?
2. Is this a steering cable issue that is causing the control valve to not move enough to allow PS fluid to actuate the piston, thus replace the steering cable assembly?
3. Or could it be a pump issue, not enough pressure?
Thoughts and guidance appreciated.
Thanks
Travis
Thanks
Travis
