2000 Mercruiser with Alpha drive...when tilting up, engine hesitates then jumps up, when trying to power down, pump sucks foam into resevoir and lower unit drops but does not power down. Tried bleeding system, no pressure on reverse line. With both hoses removed at the pump oil only comes out of the up port. Nothing coming out of the down port. Pump motor is spinning. Any idea's to troubleshoot?
