Mercruiser Power Tilt/Trim
Status
Not open for further replies.
Viking77
I am doing a PPI, Pre Purchase Inspection, and evaluation of a 19' 1979 Cruiser with a 165 hp I/O. I have read through four books now and none of them really talk about the hydraulic Pump or Rams. How do I inspect this system? What am I looking for? Is there a reservoir I am looking for? Are there any sounds that will tell me the condition of the Trim and Tilt system?
Thank you :cool:
erikgreen
Re: Mercruiser Power Tilt/Trim
I'd just try it out. Run it down and up, watch for any hitches or pauses in the raising/lowering, check to make sure when it's up and you pull on it that the lower unit won't come down (the cylinders should hold it up).
Listen to the pump, if it sounds like it's a cold car engine trying to start it might be worn, or it might just not have enough power. It should sound like a loud whirr/whine noise as long as you hold the button, with a slight winding down/slowing when you reach the limit of the cylinders.
The pump and reservoir are usually located near the engine, at the transom. It looks like an electric motor mounted vertically on a small box, with a sheet metal mounting bracket screwed to the floor. Usually painted all black, with a solenoid on the side, and two hydraulic and several wire connections to it.
natwales
I'd inspect the oil reservoir for any signs of water as well and the hoses and connections for any leaking or corrosion.
Viking77
Thank you erikgreen and natwales!
I went to ebay and down loaded pictures and prices on the pump
and hoses... I tried to insert a picture of the pump using the image
icon but it would not let me insert it ?
bayshiner
My oil in my tilt / trim resevoir seems to be getting water into it ,I checked hose connections they seem tight, does any one know how water could get in are how to seal those connections. thanks BAYSHINER
Don S
Start a new thread of your own.
Status
