auscarter12
- Joined
- Jun 19, 2015
- 59
1971 Aristocraft with a Mercruiser 165 Pre Alpha/ Just discovered this week that my trim pump will no longer work in the UP/OUT position. The solenoid clicks and the motor makes a noise, but it will not push any fluid. I checked the fluid level, have taken the pump out, cleared the lines, and still no luck. The part number on the side of this trim motor is 45060A9. It is the original trim pump with the square metal resevoir and one solenoid. Does anyone know what the direct replacement is for this pump, or can anyone point me in a direction of which pump will work to replace this even if it isn't the exact same one? Thanks
