mercruiser prop
lynnboy021
i have a 82 mercruiser 120 what pitch do i need? prop dont say no numbers
Re: mercruiser prop
Ayuh,... Try the Prop forum....
180shabah
Re: mercruiser prop
props typically don't say no nothing.
It will have numbers on it, you will have to find them - it may require removal.
Then like bondo said post this in the prop forum, just make sure you read the stickies over there first so you can provide the required information when you ask your question. I have an engine, what prop do I need - just won't get you anywhere.
APPALOOSA2
Re: mercruiser prop
14 1/4 X 19P OR 141/4 X 21P The 19 for a heavy load and some tubing and the 21 if you are just cruising.
If you do a lot of sking slalom go to a 17p.
