I just replaced the water pump/impeller on my R drive. When inspecting the upper housing, I see an 0 ring halfway across the opening to the part the drive shaft splines will go into. Is this supposed to be there? There was an O ring on the drive shaft groove when I disassembled. Also, I watched Chris video on water pump service from the stickies. the seal he flicks out of the upper unit, what is its purpose? what is it called? help appreciated.
