After a year of not being used I’m wondering if I should put some oil in the cylinders prior to starting? The motor was winterized but not fogged. I just want to be cautious. Any suggestions?
thanks
What you SHOULD do tho is change the drive oil, motor oil and filter, fuel seperator, and maybe drain your gas unless you are sure stabilizer was added.
