greg82255
- Joined
- Oct 26, 2009
- 781
Hello,
I have a 1986 Mercruiser 260 /Alpha One. I'm replacing the exhaust manifolds and risers and have heard that people often have problems with the manifold to riser gasket not sealing properly. I don't want to end up with water in the cylinders, so I'm wondering, is there any type of special way to make it seal properly? Should it be coated with some kind of gasket sealer before you put it on? or do you just make sure the surfaces are clean and flat and put it on? Thanks in advance for the help.
