Background: 1974 Mercury 888 (Ford 302) w/ 1200 hrs. Compression ~105-115 on all cylinders except one is low at ~85.
When I'm in the water, I can start and idle out of gear ~1900 RPM (vac at intake manifold steady at 20). I know this is high but here's why. When I put it in gear (ie FWD) rpm at idle RPM drops to ~1100 (vac drops and steady ~10-12). If I set the idle rpm when out of gear any lower than 1900 rpm, engine stalls when I shift into gear.
Also, recently (i.e. within a few hrs) went through general tune-up, points, dwell, base timing, idle mixture set w/ vacuum gauge.
I suspect low power due to low compression, but just wanted to check if I'm missing anything.
Thoughts? Thanks in advance.
