askiopunk4358796652
- Joined
- May 26, 2003
- 13
Have something crazy going with my late 90s Sanger V210 Mercruiser 5.7L. Sometimes it won't start with the key and I have to short circuit across two terminals on the engine. Usually goes in spurts (like won't start with the key for a dozen times) and then it will start again for a while. And it will run fine sometimes on the water and then it will just cut out like and then catch and run and then cut out. This is usually at a bit higher RPMs. It's definitely cutting out like an electrical switch has been shut off (not a bad running engine IOW). The engine runs really smooth and nice other than not starting and the cutting out.
I'm pulling out my hair trying to figure out what's going on. Not the start switch- replaced that. Plus I've wiggled about every wire in the boat looking for a short or open circuit.
Ideas?
Thanks so much! And my kids REALLY thank you since they're not able to go surfing
Ideas?
