Mercruiser special tools
Racerjoe56
I am about to put a transom kit and lower shift cable in a 1998 Fisher pontoon boat with a Mercruiser 3.0 liter /Alpha 1 Gen II drive. I understand that I will need to purchase the hinge pin tool and the engine/drive alignment tool to accomplish this but I was wondering if I "really" needed to buy some of the other tools I am seeing everywhere to do this job.
Specifially in question are the:
Exaust bellows expander tool
Lower shift cable removal and instalation tool
U-joint ring instalation tool (looks like it presses a ring on the u-joint bellows into place into the drive)
And any other tools that are a "must have"
Let me know your expert opinions as I have never been in one of these before.
Thanks
Les
Don S
Re: Mercruiser special tools
Only if you install a bellows and not the tube that is popular with the DIYers because you don't need the tool
NO
NO
hinge pin tool
If you can't get the pin loose with a 1/2" allen wrench, then yes, you need the tool.
The alignment bar is a must have, and is available on ebay all the time for around 50 bucks. You do need one. It's cheaper than the coupler.
Racerjoe56
Thank you for the speedy reply. You sound as if you have exsperience with these animals....
Any opinion (pros/cons) on which one is better, bellows or tube? I am looking for ease but also nice quiet ride......(chugging down river in pontoon)
I just ordered transom kit (Quicksilver) that comes with a bellows. The tube seems to be about $30 and the expander is only a few dollars more. No real biggy for me if I need to spend a few extra bucks when you consider the labor involved.
Also, gimbal bearing and u-joint. Do you just replace them while it is apart or anything I should look for? If replace - any special tools needed for them?
Than you Sir!
Fishermark
I've never used the tube, but most say there isn't a big noticable difference in the noise level.
For the shift cable you will need an extra deep socket - I simply welded two Craftsman 12 point 9/16" sockets together and it works great.
Racerjoe56
Got it all buttoned back together this week. I still need to adjust the shift cable. Special tools bought were:
Engine alignment bar with gimbal bearing driver and universal bellows ring driver.
Exaust bellows tool
Hinge pin tool
Shift cable tool - 11/16 deep well socket welded to a 9/16 medium well socket with 1/2 inch drive (both purchased at flea market for $1 each)
I believe it all went fairly well. Will know once in the water tooling down the river.
Thanks for the input.
