texasvet54
- Joined
- Nov 5, 2010
- 267
I didn't see any activity under "stalling" in the Mercruiser Forum, so I hope it's ok to post a question here.
I have a 5.0L Mercruiser I/0 on my Three Buoys houseboat that I purchased back in September. After taking it out a few times before the weather turned cold here in Texas, it started stalling when I dropped the RPM's down to idle to shift into gear. I had a local marine shop look at it and they determined that I needed a new carb.
I took the boat out a few weeks ago and the new carb worked fine. I took it out today and it was stalling out again when I put it in gear while in idle. It didn't stall everytime I put it in gear, but enough to be a problem. I'm going to talk to the shop that put it in this week.
If the carb is good, what else can the problem be? The carb is a two barrel and I assume that the acceleration pump in the new carb is good. Also, I haven't checked the fuel filter yet, but the original owner said that the engine was tuned in the spring of 2010.
I can change the fuel filter, the distributor and the plug wires, but I'd rather know if these Mercruisers are prone to stalling and what fixes it before I start pouring money and time into the engine.
Also, it was around 55 degrees today and the water temp was around 53.
Any ideas?
Thanks,
John
Any ideas?
Thanks,
John
