Mercruiser starboard exhaust very hot
lowvlot
I have a 97 blue water Monte Carlo I just put an engine into it last year. I put it on the muffs and ran water through it yesterday. At first I had no water at all cycling through. I turned up the hose and got water. However, the starboard side exhaust is really hot while the port side is not. I've done some searching and it seems this is a common problem. Some saying that it is normal and others saying anything from water pump impeller to blockage in the cooling line. So, I am coming to you guys for assistance.
Ayuh,.... If there's any question what so ever, Change the water pump impeller, 'n continue on from there, if that don't fix it,.....
Btw,... manifold temps are Never equal,.....
