I have a 1974 i/o mercruiser with a 165hp 250 cid engine. It has the hydraulic reverse lockout system. The throttle is broke and I bought a used replacement that has a microswitch. Can I bypass the hydraulic lockout system and use a relay to shut off the hydraulic motor? Please explain what needs to be done. I am capable of wiring and electronics; however, Im not sure what to do in this case. I understand the hydraulic lockout system was only used for a couple years.
Thanks,
Thanks,
