mercruiser thunderbolt IV dist
goingagain
I am planning to do a minor tune-up on my 5.7 mercruiser TB-IV ignition
system.. I will replace wires,plugs etc. I also will replace the dist cap and rotor and sensor wheel. my question is there any probs with changing rotor
and sensor wheel that i should be aware of. tks in advance
john
f_inscreenname
Re: mercruiser thunderbolt IV dist
If it is the first time the rotor is coming off the shaft be prepared. Merc in their infinite wisdom decided to use some sort of lock tight on them and the only way to get them off is to cut them off. I used a Dremel with a cutting wheel to go down both sides of it and then split it apart with a flat head screwdriver.
goingagain
well, my boat is in the water ready for the season, was just going to do this
on a slow fishing day. will do everything else and wait for the motor to need
rotor and sensor repair to do that part. thank u, thank u, don't need probs
that i create myself.
john
