krisnowicki
- Joined
- Jul 11, 2007
- 1,172
I am pulling the king cobra transom and putting on a Merc Alpha. The merc has a rubber seal that goes inside the outer plate.
Do I need a cork gasket too?
Also, should I use some sealant like bellows sealant on the seal between the plat and boat?
Last Q, Can I assemble the transom plae with the gimbal bearing bellows and cables then install or should I put the plate on then install the goodies?
