mercruiser trim up or down questions?
72fiberform
What does the middle button do? The other 2 trim up and down.
mjf55
Up = Trim up. ( there is a maximum that it will go up, not all the way
Up + out = Trailer up ( all the way up )
Down = down
Chris1956
To expand on what MF said: Middle button trims motor, under power. The motor has a trim limit switch which is adjustable, to allow for trim. To tilt the motor for trailering, push middle and top button together.
Bottom button is for down.
Note: A lot of those trim limit switches break. They are PIA to repair or cannot be repaired. In that case you can bypass the trim limit switch and use the buttons as designed, or simply use the tilt function for both trim and tilt.
Silvertip
Do not run the engine with outdrive all the way up. The U-joints cannot tolerate this. All the way up is a trailer or dock position.
