MERCRUISER V8 305 ONLY 3000 MAX RPM AND BACKFIRES HELP?
JEFF111568
3000 MAX RPM AND POPS ALOT AT HIGH SPEEDS. ALSO STALLS ALOT GOING INTO REVERSE. ANY HELP? 305 MERC THUNDERBOLT IGNITION.
hondon
Re: MERCRUISER V8 305 ONLY 3000 MAX RPM AND BACKFIRES HELP?
That engine has been out there along time with many different ignition,carbeuration and interrupt configurations.SO ,right down to the Mercriuser serial #,what do you have?
Spidybot
Hi Jeff,<br /><br />Welcome to our "playground". Here's a good hint <br /><br />Your problems sounds (from your brief description) to be related to either fuel or ignition.<br /><br />Have you done anything at all to check anything?
Haut Medoc
Check for ignition cap. Popping @ high rpm is usually water in fuel or bad timing, ie cracked cap. You need to give more info. J
Haut Medoc
Or some bad ignition wires. J
JEFF111568
hey , thanks for the help guys. i have a thunder bolt ignition. engine model 228r, serial # 6774023. just bought this boat used had it out 2 times now. put new gas and treatment in tank. i will try a new ignition cap and timing i guess. past owner keep good maintainace records, wires are newer plugs and cap all done 2 years ago. this boat has only 270 total hours on the meter.<br />how long do the ignition systems last in engines like this?
Haut Medoc
Check the water separator,too. J
crazy charlie
When it begins to do this,turn the motor off and look inside the dist. cap for moisture.I had the exact problem years ago and that was the culprit.Charlie
It's a Fuel Delivery Issue.............. :rolleyes:
Flukinicehole
I would replace the water seperator and take it from there.
JEFF111568
well guys I put a new water seperator & dist. cap on and went for a ride. no change in the rpm and backfires. maybe ignition box bad? or fuel pump? anymore idea's?
Skipster1
Backfires ..... first thought that comes to mind is too rich a fuel mixture.<br />Second is timing.<br />So you should check the timing first and then, if timing is okay, I'd try leaning out the mixture and see what happens.<br />These are the basics and must be answered to first, before you get into more complicated possibilities.
It's a Fuel Delivery Issue.............. <br /><br />Tank,<br />Lines,<br />Fuel Filter,<br />Carb,<br />It's going Lean .........<br /><br />You have a Fuel Restriction Somewhere.........
Skipster1
I say again.... backfire COULD indicate too rich a fuel mixture. <br />If the mixture WERE too rich it would bog down when you attempt to go WOT.<br />Doesn't take but a minute to check it out.
crazy charlie
Welcome Jeff.You will find this a great place for help if you use it correctly.You have your answer from Bondo.He is not guessing as many of us do.He is telling you where and what the problem is.The correct way to use this site is to thank him and use what he has told you (twice)and fix your problem and post back the results.You will find him to be one of the most reliable sources here.good luck!!!! Charlie
McKenzie
Sounds similar to the problem I had with my boat... anti-siphon valve at the gas tank was clogged. The difference I notice is my boat idled and shifted without stalling. Also, I could do full speed for 30 or so seconds before my carb emptied. Furthermore, my boat never backfired, it smoothly lost power. Do you stall going into forward too? If so, I would take that as you don't have a fuel restriction, because those things usually hurt your top-end, not idle. If it's just reverse, then you could still have fuel restriction, the reverse stalling could be from merc's shift assist that kills the engine for a quick sec when shifting, it may need adjusting. Does the boat act up in neutral? If it does, I would skip to the ignition system. If not, it could still be ignition or fuel related. Easiest way to eliminate fuel restriction as a culprit is to use an outboard fuel tank connected right at the fuel pump. If it fails that test, start looking at the ignition system. Start with the ignition coil and electrical. Easiest way to eliminate electrical is to attach a voltmeter to the positive ignition coil terminal, take the boat for a spin on the water and have a friend see if you are loosing volts when the issue occurs.<br /><br />The things I mentioned are probably not the fix, but these tests will help you and the forum pinpoint your problem.
JEFF111568
Hey guys, well with some help I found out that 2 of the jets in the carb are not working. so it was a fuel thing. Bondo got that one. getting parts today and will try out asap. Hoping thats it. Thanks guys
JEFF111568
Oh 1 more job i would like to do is change the stock exhaust to a thru hull exhaust. Anyone seen this done or have any advise would be very thankful.
That's a New Thread.......
