monette999
- Joined
- Jul 8, 2011
- 35
Dear All,
âsince I had to replace my GM V8 I was missing the mechanical push-rod actuator to drive a mechanical fuel pump.
So I thought use a Holley Red Line Fuel pump for carbs. 95gph. (my V8 has a single Rochester carb).
OK I thought s mart and positioned the pump in the same place as the mechanical fuel pump. Major advantage. I could used the OEM stainless steel fuel line without changing anything. See Photo:
Now here the downside: The pump is a push pump !!!
Holley says
lace the pump close to the tank. I am close to the pump!!! about two feet away. But I have the filter in front of it.
So the fuel will travel though the filter a slight loop up before it will be on the inlet port of the pump.
Holley says:Keep the pump away from the heat: That is a problem. The pump temperature will be always above the block temperature. What shall I do?
If the pump goes hot the is always the risk though thermal expansion of the pump. Will it keep the pressure when it gets hot????
Dear boat guys, please share your experience with me. I am sure that I am not the one who had this problem before.
Attached two pictures with the original setup a the new setup.
Thank you.
BR
Bob
Holley says
Thank you.
BR
Bob
