lihartke
- Joined
- Jul 7, 2013
- 20
1. stored boat over winter without filling tank and with having ethanol. mechanic winterized it not sure if he added fuel stabilizer.
2. redid upholstry and weight of sidewall was hanging on throttle cables and other wires that ran through there. Also drilled into sidewall for wingnuts to be placed in. Near top rail in front middle and back of sidewall. Tried to take shifter lever off(quick silver throttle with square button on bottom to push in to release for neutral) things fell on floor(brass coat hanger looking""z"shaped bar in front of throttle lever), didn't know it, butalso the brass metal bar with 2 prongs that attatch shifter( to throttle cables?) to allow for forward and reverse speeds on back of shifter plate. Replaced brass bar myself and took to mechanic because throttle was racing and I did not know why. He put brass bar with prongs back on and motor ran great.
3.went to reservation to get (ethanol) gas and pumps were running very very slowly(they were replacing top pumps) got 15 gallons of gas in tank to fill boat.
4. went boating in calm water for 20 mins one way. Boat ran fine(did not open her up too much, but did go reasonably fast (15-20MPH)for a couple of minutes. Stopped for an hour to eat and went back to campground boat still ran fine
5. boated for 20 mins (very choppy waters)and hit a wave and stalled within 2 mins.
6. started right back up and went tubing for 20 mins.
6. boat was hesitating and stalled when going faster
7. started back up and ran for a few mins and stalled
8. got towed off water to mechanic(boat would not start)
9. mechanic said boat started right up when he turned her over after sitting 10 mins
10. mechanic changed water/oil separator and said we had bad gas/ added stabilizer enzyme and said we would need a carburator rebuild(carbon fouled plugs) when we get home, he ran engine for 15 mins and we left doc to boat
11.drove boat for 1500 ft and she stalled just cut out
12. started her and ran and was hesitating and stalled within a couple mins
13, started and ran and stalled and restarted
14. got back to mechanic and he checked and said we need a tune up.
15. put on new rotors,distributor cap, plugs and ran boat for 15 mins at dock
16. we took off and within 600ft she started to hesitate and was acting like she was going to stall so we put her on trailor to bring home
17. started engine in driveway on muffs and heard an arching sound and found coil top arching from under wire cap. Also noticed motor trying to turn over when key was just pushed in and not turned over
18. bought new spark plug wires(one new one was bad so we had to used an old one.) and new coil.
19. took her to parts store and tried to start her(was going to work on her there so parts were available. replaced the ignition switch she ran for 8 mins and stalled
18. gave her to mechanic and they changed the ignition sensor, spark plugs, and water oil separator and said we needed carburetor rebuild and to drain the gas.
19. drained gas completely out and refilled tank with premium ethanol free gas
19. bought rebuild kit and new float for carb and new spark plugs
20. mechanic rebuilt carb said ran great on muffs
21. took her to canal (5 mph) she ran great at low idle 40 mins no more stalling
Got to no boat dock area and decided to open her up and she had no power to plane and started to sputter/hesitate went back down to 5mph and she ran a bit off but did't hesitate. Husband said he heard a "popping" sound when she was accelerated.
22. took her home and checked (new) spark plugs (after carb rebuild) and they were completly charcoal (chalky-dry-pitch-black)
23. removed fuel pump and extra air valve for emergency spillage was completely clogged with sediment debree)
24. going to buy new fuel pump and then take back to mechanic to check carb
any ideas please advise. thanks! by the way $400 at 1000 Islands, $400 at West marine $100 carb rebuild and on and on ......
