How do you know if all the water is out of the lower unit? I winterized it by doing the following: in the motor(closed system)I removed the plug from the baffel and drained water. removed hoses and blew out w/compressor. Blew out baffel. Blew out exaust(sp?). Filled all hoses and baffel with pink anti-freze. On the lower, I attached a hose to my muffs and added antifreze. I thought I was done but when I moved it into a different spot and lowered the lower unit, I had water come out.<br />Did I miss anything or was this a pocket of water sitting in the unit.<br />I gues I should go to the book store and look for the "Idiot Guide to Winterization"
