Re: mercruiser wont shift after changing water pump.
Not a problem. Push helm the control lever all the way forward. The shoe (the upper coupler) should be pointing straight ahead (forward gear). Turn the intermediate shaft (coming up out of the lower) all the way clockwise (forward gear). Is it pointed straight ahead, and does the prop lock when you try to turn it counterclockwise? If it does put a bungee on the prop to hold CCW pressure, and put it back together, making sure the top of the intermediate shaft fits into the shoe of the upper shaft. If the intermediate shaft does not line up, drop the lower unit a little farther, pull up on the intermediate shaft so that it comes free of the short splined lower shift shaft. Check to make sure there is a flat stainless steel washer in place on the lower ss (the bottom of the intermediate shaft rests on this washer). Turn the intermediate ss so that it is pointed straight ahead and push it back on the lower ss. Put it back together. Make sure the propeller stays locked in the ccw direction. Hope that was not too confusing. Good luck.
