Mercruiser y pipe corrosion
DS_G
Has anyone tried powder coating or other techniques to minimize corrosion on the lower flange area of the aluminum y-pipe, which lives in bilge water and outside raw water? This $1000 part requires pulling the engine to replace!!
Have not heard of anyone doing so but the pipe is cast iron
dubs283
Perfect seal/gasket sealer on the flange mating surfaces/o ring and sealer on bolt threads when assembling
Y pipe and gimbal housing are both cast aluminum. Bolts are stainless hence the sealer
