I inherited a 93 Petit Manan bow rider which I am in the process of restoring. The boat itself is in pretty good shape, but the electrical is a mess. When I got the boat the main engine harness was cut along with the harness running from the trim/tilt to the throttle. The throttle and trim/tilt are going to be replaced so I’m not to worries about figuring those wires outs. But I do need help with figuring out where these wires I have a pictured go. Whenever I have restored boats in the past I haven’t really had to mess with the electrical, so this is all fairly new, have not been able to find a good wiring diagram for this motor
The first question is where does this gray “hose” go which is coming from the speedometer
Second: this second stand of wires is independent of the main engine harness, and the boat has an additional harness which is still connected to the engine which feeds most of the engine components, I'm not sure where this set of wires go ( I included a closer picture of the wires for reference)
third: these set of wires are also independent of the main engine harness and I can’t seem to find where they go, I thought they may connect to an additional solenoid as the red wire looks like it may connect, but I’m not sure as there’s not an obvious point on the boat
Last, so I said of wires are coming off the throttle harness I’m not sure where they go either.
If anyone has a good wiring diagram let me know.
