long story short. I removed the head out of the engine because of a broken spark plug. got everything back together. put in fluids again. then i took the boat out yesterday it seemed to run fine however i started to notice that the temp gauge was risiing. I wasnt sure if it was a bad gauge or if the engine was overheating so i kept driving it alittle longer then i started to notice smoke coming from the engine so i shut off the engine. after about 30 minutes i opened up the expansion tank for the anti-freeze and realized it was completely empty but it didnt leak. i saw no trace of anti-freeze in the bottom of the engine. anyone have similar issue with overheating? I'm assuming i didnt put in much anti-freeze but was curious if i should be watching around for somethign else?
