Re: Mercuiser 140 cooling system
Raw water cooled. The hose from the thermostat housing to the water pump does not seemed to get much water flow. If the themostat is sticking or not opening properly wouldn't that limit the amount of water to the water pump,( limiting circulation )?<br /> The thermostat looked like the original, lots of sediment. I have also purchased the impeller rebuild kit and will change that out as well. I had the exhaust and elbow off and did not see any clogged ports. If the block is empty and I hook the muffs up, start the motor, if the block fills with water quickly, wouldn't that indicate the impeller is working? <br /><br /> Don, I am not opposed to tearing the motor down if need be, but I would rather change the impellar and thermostat first. You make me remember and old saying: "Expect the worst, you wont be disappointed." lol
