I have a perplexing problem with my 3.7 Liter I/O<br />Occasionally, while running under load at say, 3000-3500 rpm, the engine sounds like it is holding back, and is slightly hunting for power. Then after running for about 10min, it will 'snuff' or lightly backfire, and then the performance/power improves dramatically. I am running a pertronix ingnition, timing appears to be correct. Could this be that my distributor is not advancing properly ? I am also wondering if this could be some sort of backpressure problem?<br /><br />Thank You in advance for any and all suggestions.
