Re: mercuiser dipstick
You can search that motor for specs on oil capacity. Then pump or drain out the oil, fill with the correct amount of oil back into it, Then you will have the height of oil right there. Get a replacement oil dip stick at your favorite auto place. Dip into the hole all the way (if possible) When you pull it out you will have your correct height. Etching of indenting the high and low approximately 1" down from the oil height. Simple as that
