My 1985 Sea Ray 230 Weekender with a 260 Mercruiser overheats at low idle speed. I replaced the lower unit impeller even thou it did not need replacing. I removed the thermostat and it would not even cool at high speed. I installed a new thermostat (160 degree same as old one). I checked all hoses for flow and all works well. I took both exhaust Risers off and they look good. The starboard side looks like it has more water in the exhaust elbows (90s) then the port side. None of the water ports are plugged that I can see on the exhaust manifold or risers.
