Mercury 02 impeller question
tomxdana
Mercury 2002 125hp outboard.
First year boater doing maintenance on boat I bought. I drained lower unit and replaced impeller. Didn't really need to be done but being the boat is 5 years old and I didn't know where it was I wanted to check it. My question is with installing the face seal. I installed the impeller and replaced housing. The instructions say to install face seal by using tool to locate seal onto shaft. This seal doesn't seem like it would seal much and the instructions said that installing seal wrong could cause damage. Does this seal just sit on the shaft up against the housing or does it get installed half inside the housing and half outside the housing? I installed as per the instruction that came with the kit which was pushing the seal down onto the shaft using the installing tool. I have a Mercury shop manual and it didn't even mention the face seal.
Thanks for any info,
Tom
Don S
Re: Mercury 02 impeller question
You installed it correctly. It just gets pushed down to the top of the WP housing till it's as tight as the tool will allow. It's all on the outside of the housing. The tool keep it from being to tight against the WP housing, the seal will spin with the prop shaft.
tunedinc
hi. i have a 50hp merc.1987. i have replaced the impeller.positive we did it right. now i am not getting any water out the pee thingy on back of motor.the mechanic that put the impeller in,said it was sapposed to be a tight fit.i didnt realise it was to be so snug.anyway. ANY HELP I COULD GET WOUD BE GREAT.THANK YOU.
Lost in central ontario :(
