58 Alumacraft
- Joined
- May 11, 2006
- 40
My Mercury 100 died at full throttle, it felt like it seized. It started right back up and would run fine except for full throttle where it had a ticking noise and would stall. I opened the hood and noticed oil dripping from the oil pump area, took it into a Merc dealer and they found a cracked oil line. They replaced all oil lines and did a compression test and said it was in specs. I tested it myself in the garage and found top to bottom PSI readings of 125, 115, 130, 130. The ticking noise is gone and it seems to run good but I'm concerned about the way that it sounded when stalling as if it seized and the ticking noise that it made. I'm not sure how tough these engine are, would it be wise to tear it down for inspection or just run it?
