Mercury 110 1967 9.8 hp impeller question
Swampy54
Where does the water pee out on this model ?
I watched so YouTube videos and they had a hose under the cowling. Mine doesn’t have any hose or anything like that. I want to put a new impeller in it this weekend.
Thanks for any help!
jimmbo
On the Starboard Side, just below where it says 9.8 HP Twin
You are certain it is a 67? Post the Serial #
MTboatguy
The hole should be in the area that I have circled in red in this image on the lower part of the cowl, take the upper cowl(engine cover) off and look in that area you should see a hole that is routed through the lower cowl. If it is there, get a tooth pick and poke up into the tube, I have had problems with mud wasps plugging my tube up over the years.
Also, if you watch this video at the link, you can see where the stream comes out in this video.
https://www.youtube.com/watch?v=SvBetayG8js
MTboatguy
Jim is right, the motor in the video I posted is a couple of years newer, but they all evacuate water in the similar area. If you will notice the motor in Jim's video is the exact same one that I circled in the still image I posted, it was late or I would have went out and taken a picture of my personal motor, which is a '69.
jimmbo
It appears they moved the tel tale location. when I don't recall, but I know the 68s were the same as the 67. Your 69 might be in the newer, higher and further back spot
Some of the older models had a built in passage way to the tell tale.--It was under the engine block.------No hose.------Difficult / impossible to clean.----So they went to a hose / fitting from top of water jacket.
