Mercury 115 flooding problem
shawncs1981
I have a 1987 115 horse inline six that floods out after i run it for about 15 minutes. I found that the quicksilver autotmatic oil mixers are not that reliable so i unhooked it and it still has the same problem. The only thing is it doesn't completly die it just sounds like it missing but if i take the spark plaugs out and wipe them down it runs fine for a little while. Any sugestions would be much appriciated.
WillyBWright
Re: Mercury 115 flooding problem
Do any of the sparkplugs have significantly different deposits on them when you clean them off? You are premixing 50:1? I'm wondering of you have a torn fuel pump diaphragm or two (if it has two pumps). That could cause one to four cylinders to flood.
shawncs1981
Yeah some are a bit better than others but i think it only has one pump.
roger3645
Does this happen when your running WOT? If so, check to see if the carbs are opening too much.
shawncs1981
Yes it happens when i am running wide open. How can i check to see if they are opening up to much?
Windykid
I think you can take the covers off (not running) and goto WOT and look to see if the butterfly's are past full open.
Clams Canino
Put a kit in the fuel pump and clean the carbs with particular attention to the float needles and seats - and your bound to fix the fuel system.
Also, it's just as likely running LOW on fuel as flooding at WOT. Wiping the plugs means little to those - it's the stopping to DO it that causes the change. Try running it at 4000-4200 and see if the problem goes away.
Running WOT for extended periods is "asking for it" - "it" being piston meltage.
-W
OldMercsRule
-W
Wayne, Is that true of all inlines? I have two 1969 1000s and three 115s (a 1978 1150, 1979 115 and a 1981 115). The 1987 115 would be similar to the 140 at the crank I think, (so more fuel flow then my older crank rated motors). How do long do you recommend a WOT run, (which I rarely do for more then 5 to 10 minites until I back off to 4000 + or -)? Thanks, (sorry for the hijack) JR
