Marty Adam
- Joined
- Oct 4, 2009
- 8
The carberators on my 155 horse 6 cylinder are leaking from a screw plug at the bottom of each carb. I had a power problem and had them rebuilt. These screw plugs do not appear to have gaskets. Should they? I have not worked on these carbs before and will probably have to remove them to remove the screws.
Will this cause a potential headache due to my not being familiar with these? Are there other components on the inside of these?
It took most of the summer to have the primary problem solved by the shop that worked on the motor.
