Re: Mercury 115 HP Fuel Problem
Do this i bet it fixes your problem.
Remove your primer bulb line from your main tank.
Get a small 2 gallon or what ever fuel can and mix your 50:1 ratio oil fuel mixture in that.
Put the fuel bulb hole into the 2 gallon fuel can and pump the primer bulb till hard and primed.
Start your engine and let it warm up to operating temp while fueling from the 2 gallon can.
After it reaches operating temp, re connect your fuel bulb line to your main tank and fire it up on high idle to create the vacuum pressure your fuel pump diaphragm uses to draw fuel from the tank through the entire fuel system.
Think it has to run long enough to draw fuel from the tank. against gravity, fill the fuel water separator, the fuel line and the fuel filter before it floods the carb bowls.
What i did to fix this pesky problem, was add an electric fuel pump to assist in priming. The problem is that the small primer bulb simply does not have the suction power to draw fuel up a line, through fuel water separators and filters. You could pump it for hours and it would simply never get fuel to the carbs.
The fuel pump i used i got from a model aircraft i wrecked a few years back <sad day>. Check in hobby sites and stores and you may be able to rig one up for yourself too!
Flip a switch, listen to the pump run for about 30 seconds and pump your primer bulb 3 times and wahlah! Starts every time.
GL!
RC
