I just got a new merc 115 70s model has 140 compression on all cylinders a little hard to start and dies when I put it in gear but idles good most of the time. . . Maybe part of my trouble is the leaking top carb that is dripping down on the other 2?? I don't think its the float because the primer bulb gets completly hard and does make it leak any worse if you keep trying to squeeze it it seams like the gas is coming out around the main jet plug or atleast that is were it is dripping and I can't get that screw out to check for bad washer any suggestiong??
