Hey all, total boat newb here that just acquired a 197X Switzer Craft 16' with a Mercury 1150 (115hp) thunderbolt ignition 6 cyl inline engine. Was out running around the lake yesterday and everything was fine until I had to navigate through a small connecting channel that had debris on the bottom (stumps and such). In an effort to avoid hitting this crap, I pulled the motor out as far as I could using the trim without any noticeable cavitation. Well, she ended up running hot and stalled on me. After a couple of hours, I was able to start it back up without ANY problem and it idled perfectly.
So, my question is: did I totally destroy this thing, or is it going to be okay? What should I do?
I bought the "earmuffs", put those on and found that there was a rather weak stream coming from the water outlet at idle. The boat sat for at least two years before I bought it - what should I check? I'm pretty good with mechanics, but as I said, I'm a total newb when it comes to boats.
Thanks a lot!
capn
Thanks a lot!
capn
