I have a 70s model mercury 1150 115hp I had problems with the prop venilating and it was cutting off by itself like you killed the swithc I think the problem with that was the harness not beeing plugged in good it hasn't done it anymore but now my problem is I took it to the lake today with a 3blade 22p prop and and when I got there it was idling good but when I put it in gear it would die so I. Made the fuel screw a littled richer richer and that helped and it ran out the lake fine then while running wot it lost rps and was like it would only go 3/4 throttle and just seemed weak and would not idle. . . I also tried a 21p prop and it still would go wot and still didn't wanna idle or take off. . . Good compression new spark plugs any help would be greatly appreciated thanks
