Mercury 115HP 2 stroke - sputtering at 3000rpm when cold
convergent
I posted this before and the thread died off because the problem went away, but now it came back. This is a '93 Mercury 115HP 2 stroke. It starts on the first turn of the crank when cold nearly all the time and overall runs very smooth throughout the whole power range of the motor. The last few weeks its developed a problem when its cold where just around 3000 rpms it will sputter and stall a bit. If I feather it a little it will do this for about 5-10 seconds and then open on up OK. When we've been doing water skiing, it might do this for the first 1 or 2 pulls but then be fine after that for the rest of the day.
The suggestion made was to spray Power Tune into it as there may be carbon deposits building up. I read the instructions for this on the Power Tune website and it says to spray the whole can into the intake while its running and then let it sit for a while. The questions I had were a) where do I spray it in? and b) how does this work when its a 2+2 engine and 3 and 4 don't kick in until over 2000 rpms? Would I need to crank it up to 2500 with fast idle while I spray this in? That doesn't seem like a good idea to me.
Also, just thinking about the carbon deposit theory, why would this ONLY be a problem when its cold and only around 3000 rpms? I would think carbon deposits would be a problem throughout the range and even when its warmed up, no? I guess it could be carbon deposits in the 2 cylinders that don't kick in until 2000 rpm, but that brings me back to the question about how to get the Power Tune into those cylinders?
Thanks for any suggestions!
convergent
Re: Mercury 115HP 2 stroke - sputtering at 3000rpm when cold
Tonight for the first time it cut out a few times up at around 4500rpms after we were running smooth and just cruising. Something is definitely amiss on this thing and not sure what to look at. Still need help on the Power Tune questions too.
asm_
Just a guess. Besides possible blockage in fuel delivery path (carb), you may want to look at the ignition. Some Mercury uses two different winding coil to power it's ignition circuitry. One for low speed range (idle ~ 3000RPM) and the other one for high speed (3000RPM and up). A short in only high speed coil could cause the problem you are seeing.
Again, without much info, this is just a guess. The only way to confirm is the prob the stator output under power.
B
