Re: Mercury 115hp...no sparrrkkk
If you have just 4-5 volts on the white terminal, that could be your problem. The white terminal receives switched +12V from the ign, when the key is turned to either "START" or "ON". <br /><br />Only when there is +12V on both the red and white terminals will there be spark.<br /><br />Try attaching a jumper wire from the red terminal on the switchbox to the white terminal, or just a "hot" wire from the positive terminal of the battery. Then see if there's spark.<br /><br />You definitely won't to get spark with 4-5 volts on the white terminal.<br /><br />Cause of the problem could be as simple as a bad ign switch, or trouble with the wiring (I've seen the red or white wires in the external harness break from flexing when the motor turns, or from corrosion), or just a corroded pin in at the external harness's connector plug.<br /><br />Just to be sure, we're talking about the white terminal on the side of the box opposite to where the (3) distributor wires connect; same side as the constant +12V connection (red terminal).<br /><br />HTH...........ed
