Mader12345
- Joined
- Mar 13, 2014
- 18
I was asked to repost with more detail. I have a year 2000 125HP mercury outboard. Serial #:0t088785.
Engine idles fine and runs well but tops out at 4500 RPM. It should get to 5000-5250 RPM.
I rebuilt carbs, replaced fuel line, replaced fuel pump, etc. Yesterday I began the link and sync process. I adjusted the ide stop screw so that the carb shutters are fully closed. Then I put the control box at WOT (engine off), in order to adjust the stop screw for WOT.
Here is the issue. With control box at WOT, the carb shutters are not fully open (probably 3/4ths of the way). Adjusting the set screw does not make the shutters open fully because the throttle cable will not "travel" far enough to open them all the way. It is as if I need the travel on the cable to increase 1/2".
There is no adjustment to increase the "travel". I confirmed that the control box (which is universal) is installed correctly for a mercury outboard. The throttle cable (Teleflex, mercury) was replaced a few years ago, but I confirmed it is compatible with mercury.
How do I get the shutters to open completely? I'm thinking of buying a new throttle cable but I'm not convinced that is the issue.
Thanks. I'm in Atlanta.
