Mercury 125 Prop Pitch
cford28
Boat; 2000 Pro Craft Pro 175 Bass Boat (17'2" / 84" beam)
Engine; 2000 Mercury 125 (2+2)
Prop; Laser II 26 Pitch SS
Top Speed; 51 GPS With One Person / Gear
Hull / Engine Weight; 1649 lbs without persons / gear
I have suspicions that this is too much prop for the boat / engine. The boat lags out of the hole and sometimes chokes the engine out when dropped into gear from idle (hotfoot installed). I have a difficult time reving 5000 RPM's unless trimmed way out and WOT RPM for this engine is 5250. I have been told that dropping to a 24 P prop will be a better all around prop choice for this boat. Also, I would like to stay with SS / Laser II unless anyone has knowledge of a better prop for smaller fiberglass bass boats.
Thanks for the comments............can't wait til' spring :rolleyes:
Dhadley
Re: Mercury 125 Prop Pitch
Have you tried raising the motor? That may bring the top rpm up. If you can use 100% of the trim range without venting, that's normally a sign the motor can go up some.
Shutting off going into gear doesn't usually have much to do with the prop, that's more of a motor function.
The Laser II is a pretty good prop but there are props out there with more lift. What's the diameter, 13 1/2?
cford28
I am not sure what the diameter is...it is a small hub 15 spline if that helps.
The engine is set on the second hole, from top.
I was told that the engine stopping when dropped into gear was "possibly" from the prop turning too much water for the engine (especially since it's the 2+2 combo)
Other than that, I just trying to seek opinions before dropping 3-4 hundred on a prop that will do nothing for me.
Dhadley
Have you tried it any higher than that? If not, I'd go up one and test again.
steelespike
Motor height could add some rpm and as much as 1 or 2 mph. and doesn't cost anything.Not an expert but 26 does sound like a lot of prop to me.
Dropping to a 24 same brand same model should add about 400 rpm
And a chunk of hole shot.I would raise the motor first then consider a prop change.
