I have a 1988 Mercury 150 hp XR2 v6 ob. and its been rebuilt about 3 years ago, and it idles fine,and runs good at top end, its got good compression about 115 lbs all around, have went thru the carbs and cleaned needle valves, the plugs always seen slightly damp and dark in color,I ran a test on the trigger and stator according to the book, and where is calls for 5400 to 6200 olms on the stator I get 1650 on one and 1970 on the other, and where is calls for 1100-1400 olms for the trigger I get .755 olms and for a test between the red wire and ground and red/white wire and ground, on the stator it calls for 125-175 olms I get .055 on both, <br /><br />the boat seems to run fine when just running around but as soon as I try to pull a heaver skier on salom I can go around the lake at 5 mph and soon as he lets go Im gone. I have a 14 1/4x17 prop. Could the stator and trigger cause this?
