I have a 1997 150 carb merc v6 and the oil system drive gear failed. I had it replaced for $800 and when started it ran for about 10 minutes and the oil waring horn came on. The mechanic says I overheated the engine (running with a water hose) and damaged the just replaced gear.Question ? Can a short time over heat melt or soften or damage the plastic material drive gear?
I can't afford another $800 so I will run a 50:1 gas mixture. I need advice on disabling the oil pump REFERENCE thread 2241. I have two oil tanks one engine one reserve. A question is the crank case vacuum/pressure hose to reserve tank- how do I cap it off or disable it? What affect will this have on the engine ?
I have a plate to cove the oil pump hole so I can remove it but what about the drive shaft? Remove it?
