mercury 150 runs rough and dies
eric1111
i just bought an 85 mercury blackmax oil injected 150. it ran bad. i cleaned the carbs and adjusted the floats. ran alot better. still idles a little rough and back fires or misses ever 30 to 45 seconds ,but not on que very intermittingly. it seems to run ok(a little rough but not that bad) on muffs but once in water it acts up. i put it in an 55 gal. tank at the house were i can work on it. i replaced spark plugs and wires they are firing hot.. checked compression ok. unhooked oil injection and premixed fuel. no change. noiced that the 2 lower carbs are leaking fuel. removed carbs and rechecked all work. still ok. pump the fuel up and i can hear it enter in the carbs until full then it stops and and primer gets hard. engine cranks up and dies(runs about a minute) check plugs there are wet. tried restarting and noiced fuel still leaking from bottom 2 carbs. there is an enrichment valve on the side. i unhooked it and cranked. engine will not start but carbs are not leaking...asked a dealer's tech. if this maybe the problem he claims there is a hole in my fuel pump diapham.. i checked the diapham and no hole. also noiced today no water coming out pee hole but there is exhaust coming out.. and there is no exhaust coming out prop until 2000 rpms..there was exhaust coming out prop at idle with muffs on..is it possible i have exhaust restrition..i was told adjust fuel to air ratio ,but can not find screw. can anyone help...thanks
tashasdaddy
Re: mercury 150 runs rough and dies
do you have , a manual?
phatmanmike
you need a manual. i dont have mine in front of mee, but thsi is all covered in the trouble shooting section. all about tune ups.
replace the fuel pump diaphram regardless of what you see. it only takes the SLIGHTEST micro hole and then your stuck. its a cheap fix, just do it and be done.
studlymandingo
Agree with Mike, pinhole in the diaphragm and the pump isn't doing it's job.
eric1111
thanks, i'm going to replace it anyways all ready have it apart so figured perfect time to do it. still waiting on manual to arrive.
eric1111
sorry about delay..thing came up. replaced water pump t-stats and pop it valve and rebuilt fuel pump. starts up easy and idle good no more popping in the exhaust...water flow great,
but i can not go more than about 5mph pretty sure stator is my problem going to ohm in after work.
eric1111
ohmed stator
red-blue=6600
red/wht-blue/wht=48000
red-grd=159.9
blue-grd=159.9
defintanly bad staor go to replace it....will post results later...
