Mercury 150 Won't Shut Off
IslanderVT
This isn't my boat, but hoping to help a friend with what sounds like a simple wiring problem on his ~1986 Mercury 150 O/B.
He is using older Mercury controls and had to manually connect the control wiring at the engine. Everything works fine, except he can't shut the motor down after it starts.
As I recall, there is a "kill switch" wire on these motors that needs to be grounded to shut it down. I assume its the same wire that would connect to a kill lanyard?
Anyone know how this kill switch is connected? Also if anyone has a schematic of this wiring, that would be super helpful!
(sorry if this is a dumb question...I don't usually mess with outboards!)
Chris1956
Re: Mercury 150 Won't Shut Off
A kill switch is for emergency use. The keyswitch should shut it off as well and is the normal method. Black/yellow wire is ign killer wire. With ign switch in off position it should be connected to black ground wire.
